04-19-2019
05:31
17:10
RicardoFitbit
04-19-2019
05:31
17:10
RicardoFitbit
Hello Everyone.
I have an Ionic. I purchased it used. The person I purchased it from, didn't say anything about it not charging slow. I plugged it in my computer USB. I went from 0% to 10% in about 8 hrs. I purchased a brand new charging cable. Hooked that up and again to the computer USB. and it is still at 10% over 6 hrs.
What should I do now? Thanks for the help.
17:19
08:21
04-19-2019
17:19
08:21
Hi @jback1131 let me give you a warm welcome to our Community! I'm glad to help you out with this concern.
Seems odd that your Ionic takes that long to charge, this is definitely not an expected behavior. I'd like to suggest you to do the following:
Also, after attempting the steps above, I recommend you to restart your device and check the battery behavior while charging.
Please keep me posted, I'll be around 🤓
Best AnswerHello.
Thank you for getting with me.
I tried all of that. I even was on with tech support. They came to the conclusion. That the battery is bad.
Thanks
13:22
08:21
04-24-2019
13:22
08:21
Hello again @jback1131 you're welcome, thanks for your reply and update.
First, I'd like to appreciate your time and effort troubleshooting this matter with me. I'm glad to know that our Support team is already assisting you with your Ionic device charging difficulties. If you have any inquiries regarding the conclusion of this battery behavior, I recommend you to contact them to receive further assistance with more information and details.
Let me know if you need anything else!
