01-20-2019 14:21
01-20-2019 14:21
My ionic clock display will only flash briefly. It flashes multiple times. Notifications work fine. I’ve tried to reset it with no luck. Any ideas?
Best Answer01-20-2019 14:59
01-20-2019 14:59
@AnnieSad wrote:My ionic clock display will only flash briefly. It flashes multiple times. Notifications work fine. I’ve tried to reset it with no luck. Any ideas?
Sounds glitchy. The normal troubleshooting guesses are to do the restart a few times in a row - shutdown - change clock face. Leaving factory reset as a last resort option as some report their devices brick doing that. Failing that try contacting Tech Support. Normally if defective they will immediately replace it for you.
