07-28-2018
07:34
10:58
07-28-2018
07:34
10:58
My ionic is not getting paired with Sony Bluetooth headset model WI-C400. Can anyone help.
Best Answer07-29-2018 11:05 - edited 02-11-2024 09:57
Welcome to the Fitbit Community @Abhineel! If you want to connect a Bluetooth audio device to your Fitbit Ionic, check this article for instructions.
Make sure both, your headphones and Ionic are in pairing mode (for the Ionic: Settings>Bluetooth>+New Device). Also, make sure your headphones aren’t already paired/connected with something else, like your phone if previously paired.
If keep having difficulties pairing your headsets to your Ionic, here are some steps that also worked for me:
If your phone is managing multiple Bluetooth connections simultaneously:
These interruptions are typically caused by operating system and Bluetooth limitations. It's also possible that an app on your phone is causing the issue.
If you have an Android phone, try these steps:
The API used in these apps makes it difficult for Fitbit to communicate reliably with your phone. Ford provides a list of apps but note that other companies may use the API as well.
