09-10-2018
10:59
06:56
09-10-2018
10:59
06:56
I'm having problems with syncing my Iconic. Was working great before the update. So, I deleted the device from my phone and attempting to add again. It's been "connecting to tracker..." for 4 hours with no luck. Any help? This is my 4th fitbit device and have never had any issues. I update from the surge to the iconic about 6 months ago.
Here are some steps you can try. I had to do a factory reset of my device and this is what I did to get back:
1. remove the app from your phone and then re-install.
2. go to the bluetooth of your phone and remove your device - basically unlink your device from the phone.
Try to re-link the Ionic with the app. See if this helps
Warren | Cincinnati, OH
Versa Lite, Ionic, Charge3, Inspire HR, Blaze(retired), Alta( retired),- Pixel 3
It's nice to see you around the forums @psquinette! I totally agree with @wtksk8r. Since your Ionic is no longer paired to your Fitbit account that could be a reason of why it's not syncing or connecting to your phone's Bluetooth. In order to solve this, please go to the Bluetooth settings on your phone and remove the tracker. In the list of Bluetooth devices you'll see the Ionic and next to it, this symbol "!". Hit the symbol and it will take you to the next step, once you're there select the option that says "Forget this device".
Once you've made sure about that, go back to the Fitbit app, go to the "Account" option in the upper right corner and select "Set up a Device". This should start the setup process for your device. ![]()
If you can't get started with your Fitbit device, usually a missing requirement is the cause. Carefully review the requirements below, if you're using the Fitbit app for iOS, Android, or Windows 10:
If you're still unable to set up, try these troubleshooting steps:
Give this a go and let me know the outcome!
