05-11-2021 02:52
05-11-2021 02:52
Ionic doesn’t maintain Wi-Fi connection for more than a few seconds. Have rebooted Ionic multiple times. Have tried using app on daughters iPad 4th gen that used to work fine connecting wifi to Ionic and also my iPhone and 2 different wifi networks right next to routers but not working. I can see from router activity that the wifi connection is being made but then it drops off a few seconds later. App is up to date and Ionic is up to date. Bluetooth is fine. Any help would be appreciated. I am very reluctant to do a factory reset in case the Ionic doesn’t restart, this is based on user experience listed in forums.
Best Answer05-11-2021 03:03
05-11-2021 03:03
What problem is this causing? I ask as the wi-fi is not really used for much:
"Connect your Fitbit watch to your Wi-Fi network to download playlists and apps from the Fitbit App Gallery, and for faster firmware updates."
Mine always shows disconnected but does connect ok when needed for those functions.
05-11-2021 03:41
05-11-2021 03:41
Best Answer05-11-2021 03:57
05-11-2021 03:57
I'm not sure if clock faces are loaded over wi-fi or bluetooth. That quote from my previous post doesn't mention clocks nor does the help file it came from: https://help.fitbit.com/articles/en_US/Help_article/2233.htm?Highlight=wi-fi
Just in case it is a wi-fi issue, have you gone through their troubleshooting guide at: https://help.fitbit.com/articles/en_US/Help_article/2249.htm ?
Are other bluetooth functions, such as syncing, working ok?
05-11-2021 04:21
05-11-2021 04:21
Best Answer05-12-2021 00:09
05-12-2021 00:09
I'm afraid I don't know what else to suggest other than contacting customer support via contact.fitbit.com
Since your post I have seen several others reporting issues with loading clock faces on various fitbit models but I have not yet seen anything from Fitbit to acknowledge an issue.
