04-06-2019
05:01
05:28
SilviaFitbit
04-06-2019
05:01
05:28
SilviaFitbit
Getting seriously down with Fitbit products now, this is the 3rd Ionic we have had and all have given problems.
This one will now not charge, remains on 0% so no “resetting can be done?
The help tips mean nothing right now, Agent support in this part of the world sucks, which cuts out that option!
Has anyone out there got any possible solution or viable suggestions?
Moderator edit: format
04-08-2019 05:27
04-08-2019 05:27
It's great to have you here @Cloudhopper! Thank you for the details that you've mentioned. I would like you to try charging it once again but this time change USB ports and if you get any display then you can try restarting it.
Keep me posted, if after trying the above your Ionic is still not working; I can create a case on your behalf with our Support team. They can provide you with more options.
04-08-2019 05:35
04-08-2019 05:35
04-08-2019 11:14
04-08-2019 11:14
Thank you for getting back and trying the procedure I've posted above @Cloudhopper. I'll be happy to create a case with Support, they will continue assisting you on this matter.
04-08-2019 11:16
04-08-2019 11:16
