03-10-2020
07:15
10:55
SilviaFitbit
03-10-2020
07:15
10:55
SilviaFitbit
Hi,
my Fitbit ionic won’t charge - it’s stuck on 0%.
ive read through some similar posts that suggest cleaning the charging point etc, I have done this - no luck!
others have suggested a new charger - again, I have done this and it’s not worked.
I only bought this at the end of December!!
Any help/suggestions would be greatly appreciated.
Thanks
Carrie
03-11-2020
10:54
06:45
03-11-2020
10:54
06:45
@Carrie9019 Welcome to the Community. Thanks for the research done prior to posting.
I appreciate the troubleshooting tried.
Let's fix this together. I would like you to confirm you've done all the troubleshooting posted in this article: Why isn't my Fitbit device's battery charging? Have you restarted your Ionic?
Keep me posted. I'll be around if you have any additional questions.
Best Answer03-11-2020 12:23
03-11-2020 12:23
What if following all of the resets, power offs, charging for 30 minutes and the screen is still black, no 0% battery logo either?
Over the past month or two the battery seems to be not holding the charge as long. The device is 14 months old.
03-12-2020 03:27
03-12-2020 03:27
Hi, thanks for response.
Yes have tried all things suggested in that thread. Again, have tried restarting/booting it
Its as if it is completely dead.
15:12
06:45
03-13-2020
15:12
06:45
@Powderjockey Thanks for getting back. I appreciate the troubleshooting tried and the details mentioned.
In this case, I've shared your post with our Support team and they will continue assisting you through email, please check your inbox.
03-13-2020 17:58
03-13-2020 17:58
I had an Ionic stop charging a couple of months ago. Did everything suggested with no result. Contacted customer service and went through all the steps again with them. It was less than a year old. Finally, they replaced it for me. Last night, it synced, then this morning, it had no charge and will not charge. Less than 3 months old. This seems to be an ongoing problem with this model. I have worn Fitbits since they came out, but I am very disappointed in this tracker. I doubt they will send me a new one again. Now what?
13:23
06:38
03-14-2020
13:23
06:38
@PupperMom Welcome to the Community. Thanks for the details mentioned and the troubleshooting tried.
Sorry to hear that you're experiencing this with your watch. Each case is reviewed individually and the option provided is based in the Fitbit Warranty. If you have any questions about the option you're given, you may want to reply back to the case that you have.
