Ionic not charging
Hi I have 2 lonic. Fitbits they are not working will not charge will not do anything only got them in may last year
2 REPLIES 2
Presumably you have two charge cables?
May be one is faulty?
Try connecting them to a computer to verify they are detected (making a good connection with the charger).
If the problem occurred after a firmware update, it could be the cause as others are also reporting the same issue.
Thanks for your help @Guy_. Welcome to the Community Forums @brendahupton
Thanks for the details shared on your post. In addition to what @Guy_ has mentioned, I suggest reviewing our help article for Why isn't my Fitbit device's battery charging? for additional tips.
Hope this helps.
Cindy|Community Moderator| Did you find my post helpful? Vote for it or mark it as a Solution!
