12-30-2018 00:27
12-30-2018 00:27
Can you tell me where I can send my ionic as it won’t sync with Bluetooth . I have tried to switch on and off numerous times . I finally reset factory settings but can’t sync to Bluetooth to re load . I’m in Sydney
Best Answer12-30-2018 22:50
12-30-2018 22:50
You originally said 5 SE, which is not on the list. If it just SE, yes it is there and should work, but if it is 5 SE it may work or may not.
Helen | Western Australia
12-30-2018 00:41
12-30-2018 00:41
What phone are you using? It might be a compatability issue.
12-30-2018 01:16
12-30-2018 01:16
Best Answer12-30-2018 02:48
12-30-2018 02:48
It surprised me a bit, but I cant see that phone on the Supported Devices List. That may be why you are having problems. Phones that are not supported often work until something upsets the connection (usually an update To phone or tracker), but because it is not suppprted no one is working towards getting it going again.
But first check that notifications are still turned on on the actual Ionic. Long press on the left button and go to the quick menu page (you may need to swipe to the left) and check that notifications are still ON.
If they are, try THIS Help Article on troubleshooting notifications.
12-30-2018 22:17
12-30-2018 22:17
12-30-2018 22:50
01-10-2019 19:00
01-10-2019 19:00
