10-19-2019
16:16
06:51
10-19-2019
16:16
06:51
@Westernsky Welcome to the Community. Thanks for the details mentioned.
It's pretty weird that you tracked the activity using GPS but it didn't record any distance or steps. I would like you to make sure you're tracking it doing the following:
Please make sure that your GPS is showing as always connected while you're running because if it's loosing connection it might be the reason why the data isn't always tracked.
Keep me posted. Best of luck with your marathon. 😀
