12-11-2020
01:19
11:55
RicardoFitbit
12-11-2020
01:19
11:55
RicardoFitbit
Hi
My ionic is displaying any of the middle stats when I start to run eg, the heart rate, pace, pace per average, times etc
Noticed its the same for stop watch where numbers are not showing up
Can you advise
I have restarted etc
Thanks
Best Answer12-11-2020 01:20
12-11-2020 01:20
I meant to put its NOT displaying info whilst on running set up
Best Answer12-11-2020 11:56
12-11-2020 11:56
Hi @RunnerRest, welcome to the Community Forums.
Thanks for bringing this to our attention and for restarting your device before posting over here. For a better understanding of the issue you're currently experiencing with your Ionic, can you please send me a picture of the information that's not being shown while tracking an exercise activity?
Looking forward to your reply.
Best Answer12-14-2020 07:22
12-14-2020 07:22
Best Answer12-15-2020 19:06
12-15-2020 19:06
Your reply is appreciated @RunnerRest.
It seems that the picture wasn't attached correctly into your post, can you please try again to send me such information but now take into consideration the steps from this post to correctly attach the image?
I'll be waiting for your reply.
Best Answer12-16-2020 01:00
12-16-2020 01:00
Best Answer12-18-2020 11:31
12-18-2020 11:31
Thanks for your update @RunnerRest.
I'm sorry but it's not working as it should, the screenshot wasn't attached to your reply. Can you please try using the Community Forums from a computer instead?
Looking forward to your reply, your patience is appreciated.
Best Answer01-09-2021 07:23
01-09-2021 07:23
Yes when i have access to pc I will do that
Thanks
01-11-2021 14:27
01-11-2021 14:27
Thanks for your reply @RunnerRest.
If by any chance the screenshot isn't attached correctly again, please try sending it directly to me via private message. Just click at my profile and then click on Send a Message. You'll find there a little camera icon where you can upload an image and send it to me.
Keep me posted.
