07-26-2021 01:40
07-26-2021 01:40
My ionic has suddenly stopped holding its charge . It goes from 100% to zero in only a few hours. Up until now it has been working fine and I can normally go 3-4 days without a charge. anyone else?
Best Answer07-26-2021 02:27
07-26-2021 02:27
Did you do the recent firmware update?
Best Answer07-26-2021 05:00
07-26-2021 05:00
Leave the Ionic on its cradle or charger for a few hours or let it sit there overnight. In the morning, check to see if it turns on or if its battery is fully-charged. If it did not charge, then make sure that it's not wet by wiping off its contacts with clean, dry tissue paper.
Best Answer07-26-2021 05:03
07-26-2021 05:03
@oliveadams1 wrote:Leave the Ionic on its cradle or charger for a few hours or let it sit there overnight. In the morning, check to see if it turns on or if its battery is fully-charged. If it did not charge, then make sure that it's not wet by wiping off its contacts with clean, dry tissue paper. UPSers
Thanks for the info i will try to figure it out for more.
Best Answer07-26-2021 11:00
07-26-2021 11:00
I have the same issue with my Ionic and it was just replace. It was doing it when I got the new replacement. I was told to restart, which doesn't make sense to me. I was also referred to this link which so far all I have read are Ionic users having holding a charge issue. By the way I am on my third Ionic may be time to make a brand change. I think I read insanity was doing the same thing over and over and expecting a different result?!
Best Answer07-26-2021 12:59
07-26-2021 12:59
Change the clock face. Some clock faces eg the SPO2 clock face suck huge amounts of battery power. When I changed from the SPO2 I have returned to charging every 3 to 4 days from being where you are.regards Des
07-26-2021 13:08
07-26-2021 13:08
To check charge level while charging move the charge connector a little to about 45 degrees to break the connection then reconnect to 90 degrees. This will cause the charge level percentage to temporarily appear on the screen. Nice easy check to see how the charging is going. See my earlier comment on clock face as possible cause of high battery drain.
Best Answer07-27-2021 08:42
07-27-2021 08:42
Thanks Des. I cannot get any charge into the watch at all. I think it may be time for a replacement!
08:48
10:39
AndreaFitbit
07-27-2021
08:48
10:39
AndreaFitbit
No I didn’t get that far. The update came up after the watch died yesterday!
I tried leaving the watch but it did not charge at all and the sensors are dry.
Moderator edit: updated post.
07-27-2021 12:04 - edited 07-27-2021 12:09
Welcome to the Fitbit Community @PokerPaul and thank you for your comments and assistance @SunsetRunner, @oliveadams1, @KiwiDes.
@AlvinP, are you still experiencing the situation with your Ionic? Were you able to resolve your inquiry with our support team?
You can follow instructions of help article: Why isn't my Fitbit device's battery charging? @PokerPaul.
Keep on visiting the forums.
