12-26-2018 11:49
12-26-2018 11:49
Hi all, I have just bought a Fitbit Ionic for my wife and we haven't had any joy with it yet. We have synced the FitBit to a Samsung Galaxy J3 and started the initial setup. We then started a Firmware update but the installation phase failed. The Fitbit then just started to slowly flash the update/diamond logo and was no longer visible on Bluetooth and was completely unresponsive. We spoke to the online support gurus who talked us through a factory reset - this was "incomplete" but at least the FitBit was then visible as a Bluetooth device again. We started the initial set-up again (after restarting phones etc) but the initial setup fails repeatedly at the installation phase (step 3/3) and the FitBit reverts to the non-responsive flashing... We haven't actually seen the FitBit do anything other than its initial welcome message and the flashing and are thinking about just taking it back for a refund/giving up with it. Has anyone got any ideas or had similar problems?
Best Answer12-26-2018 12:03
12-26-2018 12:03
“We haven't actually seen the FitBit do anything other than its initial welcome message and the flashing and are thinking about just taking it back for a refund/giving up with it. Has anyone got any ideas or had similar problems?”
If this occurs in a brand new device after a factory reset -> yeah take it back for a refund.
You are in for a lot of pain otherwise one would suspect. Read thru some threads here. If you really want -> get a new one and try again. FYI Fitbit sent me a replacement Ionic after about a week. So that might tell you something about the reliability of this device.
Best Answer12-26-2018 12:24 - edited 12-26-2018 12:29
Since having the ionic seen by the Bluetooth, will not affect the setup provess and possibly the formate update that normally goes through WiFi and completely bypasses the phone. I don't even worry about the Bluetooth screen on the phone, except to remove the tracker from the phones Bluetooth. Being attached will often prevent the setup process to function properly.
Normally I just cancel the firmware update and restart.
You say that the initial setup fails at the installation phase. Is this the phase where the tracker gets attached to your Fitbit account? Or is it when the former is getting installed.
