03-15-2018
11:52
06:05
03-15-2018
11:52
06:05
I have had a number of troubles syncing the device with the app. My Ionic seems to work just fine but will lose syncing ability with the iphone app. Everything is up to date and I have to restore the watch to get it to sync every week or so. Takes a long time and is frustrating. When it does sync it is not updating the sleep information. I assume my Ionic has the data but is not getting to the iphone application even though it is connected via Bluetooth and the steps are tracked. Any suggestions?
Welcome to the Fitbit Community @keithlead! I'm sorry to hear about the syncing inconvenience you've been having between your iPhone and your Fitbit Ionic. Keep in mind that syncing difficulty is usually caused by a missing requirement. Verify each requirement before moving on to the troubleshooting steps:
If your device still won't sync, try these steps:
On the other hand, when it comes to your sleep data, I was wondering if your Ionic is not picking any sleep data? There are a few scenarios where you might not see the sleep stages but sleep patterns instead:
Please check these scenarios and the troubleshooting steps for the syncing issue and let me know the outcome!
I have tried all this solutions including get an new phone and a new fit bit Watch. My ionic still continues to sink sleep erratically even though it Definite records it
Best AnswerI have the same problem. Have tried everything, all is up to date.... just doesn’t sync sleep data well. I end up waiting all day until it eventually syncs... no telling when that’ll be....
definitely something that needs fitbit’s attention.
