08-29-2018 04:46
08-29-2018 04:46
My Ionic has suddenly stopped syncing with Strava today. Anyone else had issues? Everything was fine yesterday. I also noticed today that I can’t see any Strava logged activities on my ionic (in the Ionic’s Strava App) any later than July??
09-07-2018 00:35
09-07-2018 00:35
Fitbit are looking into the issues with Strava syncing. Keep an eye on the following thread where they are posting updates:
https://community.fitbit.com/t5/Third-Party-Integrations/Strava-syncing-with-Fitbit/td-p/2937775
Best Answer08-31-2018 03:29
08-31-2018 03:29
Hello and welcome @Kelbram. I'm guessing you are doing the same activities (as before that aren't being picked up now), but before I can offer some suggestions, please reply back or PM me with the type of activities that Strava is posting (Walk, Run, Hike, etc...).
Thanks and Keep on STEPPING!
Gunny | Richmond, VA (USA)
Ionic Adidas Edition, Versa Special Edition, Aria 2 & Flyer | iPhone & Windows 10
Take a look at the Fitbit Help site for further Assistance & Information.
Best Answer08-31-2018 03:59
08-31-2018 03:59
Best Answer09-06-2018 18:35
09-06-2018 18:35
Mine is doing the same... after resets/log ins and outs/etc...
Best Answer09-06-2018 21:02
09-06-2018 21:02
I'm having the exact same problem!
Best Answer09-06-2018 21:04
09-06-2018 21:04
I'm having the same issue...it's not synching. I've upgraded the fitbit app and I've disconnected and reconnected strava to fitbit. So what should I do. I have an Ionic.
Best Answer09-07-2018 00:35
09-07-2018 00:35
Best Answer09-07-2018 06:15
09-07-2018 06:15
Hello @Booster216 and @Peteck18. Please tell me what exercises you are doing that are not syncing between your Ionic and Strava. This will enable me to assist you better. Thanks
Also, please follow @SteveH great advice (thanks Steve) and his link for additional information.
Hope this helped and Keep on STEPPING!
Best Answer09-07-2018 08:35
09-07-2018 08:35
All of my runs (which is usually the same route on the same day of the week)
and my bike rides...
Best Answer09-07-2018 08:54
09-07-2018 08:54
Best Answer09-07-2018 09:02
09-07-2018 09:02
I ended up doing the same to my exercises (uploading manually), but it is kind of annoying... All my exercises have not uploaded automatically since August 30th... Not a one day deal...
Best Answer09-07-2018 10:11
09-07-2018 10:11
My bike ride is not synching.
Best Answer09-11-2018 13:24
09-11-2018 13:24
Hi everyone! Our team has some mitigating fixes and syncing should be back to normal now. Can you please let me know if this is working for you? ![]()
Note that this is not a retroactive fix, so old activities may not sync to Strava.
Thanks again for your reports and patience. Let me know if there's anything else I may assist you with!
09-13-2018 18:21
09-13-2018 18:21
Again my fitbit Ionic is not synching with strava - second time in a week - after another big event. I'm getting pissed. What's going on!
Best Answer09-13-2018 18:36
09-13-2018 18:36
Yuuuuup... same with me...
Best Answer09-17-2018 06:26
09-17-2018 06:26
Hey there @Peteck18 and @Booster216, thanks for stopping by! If you're having problems with info syncing from/to Strava, you could try to remove and add Strava back to Fitbit. For this, you can go to your online dashboard and then click on the gear icon at the top right corner.
From here, look for the Applications section on the column that is on the left side. Here, look for Strava, click on the Remove Access button and then go to Strava to link Fitbit again.
If the issue persists, I'd like to recommend that you get in touch with Strava's support team. Given that this connections are developed by the third parties, they should be able to see what is going on and help you get it resolved.
Having said that, you could export the activities you want to have on Strava and manually upload them that way.
Let me know if you have any further questions.
Best Answer09-17-2018 12:19
09-17-2018 12:19
Thanks for the info. As of this morning, everything seems to be okay. I appreciate your reaching out. Hopefully the issue is resolved.
Peter
