08-23-2020
04:12
11:51
SilviaFitbit
08-23-2020
04:12
11:51
SilviaFitbit
My iconic won’t sync with my phone. Every time I’ve tried I’ll get the numbers sent to my watch n then after a couple min a message will appear on my phone says there was a issue and that’s it. I have tried deleting the app and reinstalling, restarting the watch, turning blue tooth off n on, restarting the phone and made sure everything was up to date. At a loss n getting very frustrated cause now not showing the correct time. Thanks in advance
My watch will sinc in the morning but won't again for the rest of the day. Thinking of buying a new watch
12:14
06:14
08-28-2020
12:14
06:14
@Jimcut Welcome to the Fitbit Community. Thanks for the troubleshooting tried prior to posting and the details shared.
I see where your frustration is coming from. Based in what you mentioned, it seems that your Ionic isn't paired to your account anymore, please try the procedure posted in this article. I know you already tried some of the steps mentioned there but following the whole procedure could help getting your Ionic set up again.
@Brodz Welcome to the Community. Thanks for the troubleshooting performed. Before you leave, I would like you to confirm that you tried this syncing troubleshooting and please double check if there is a new firmware update available to you.
@Maxhol Hey there! Thank you letting us know that you contacted our Support team.
@Chelseawill Welcome to the Fitbit Community. Please follow these instructions to correct the timezone in your watch.
@Rainegill A warm welcome to the Community! In order to provide you with the best troubleshooting possible, please provide me with more details about the issue you're experiencing. Is your Ionic not syncing or the timezone is incorrect?
I'll be around if you have any additional questions.
I've managed to get mine working again but it was trial and error and I had to uninstall the app and reinstall which seems to have done the trick - even though I'd tried this before.
A real death defying challenge just to change the time on a watch...I'll try the number Thank you but in the future do not let anyone associated with this problem put a chip in your brain
Best AnswerI have had synching issues between my iPhone 11 and Ionic every day. I've tried all the steps that have been outlined in the posts. The only way I can get my iPhone to sync is to take it off my wrist and turn it over on the face on a table until the green light stops flashing. I leave it a few minutes and amazingly it syncs up to the point the watch was taken off. This also works if you connect the watch to the charger. It almost seems that the watch cannot sync and record activity at the same time...so wondering if there is some kind of flaw in the memory or a flaw in the GPS that does not allow synching and recording activity at the same time.
I am on the latest iPhone version and the most recent Fitbit firmware version.
One anomaly observed is the bluetooth connection keeps flipping back and forth between connected and not connected (looking vs sync now) about every second.
18:04
06:14
09-02-2020
18:04
06:14
@Brodz Thank you for getting back. I appreciate that you shared that you decided to buy a new watch.
@Rainegill Thank you for letting us know that you were able to get it working.
@AutumnDunlao Thank you for getting back. Before I create a case with our team please let me know if your Ionic hasn't been set up to your account and if you're still experiencing syncing issues.
@blackstone1810 Hey there. Thank you for the detailed information shared. In this case, I've shared your post with our Support team and someone will reply to you as soon as possible. Keep in mind that due to recent events affecting our operations we may take a bit longer to get back to you.
I'll be around if you have any additional questions!
