Hi, since last night my ionic wont sync. I have tried the woraround from previous posts twice now by unlinking to bluetooth and delwting and re adding my ionic but its not solved the issue. Please help!! Its also deleted my selected excersises so i am currently about to start a 10 mile training walk amd now dont have the gps walk function on my watch and cant re add it from app because it wont sync. Very, very unhappy given the cost of this device!!
First thing you want to do is to remove the Ionic from your pH nes Bluetooth. There is no reason to try and find the tracker through the Bluetooth, the app needs the tracker disconnected from Bluetooth during the setup process.
Let's see if we can fix the cause of the no sync issue, once we do the tracker will be able to be setup. Please note that removing the tracker from the account will only add problems.
Steps to try on Android
Check for any Fitbit app updates.
Restart the ionic, better to shut the Ionic off.
Restart the phone. I had to shutdown the phone, .restart don't d not work, yesterday to get it to sync.
Through the phone settings, clear the fitbit apps cache and kill the fitbit app.
If you remember the fitbit password, try clearing the data.
Remove the Ionic from the phones bluetooth.
Now let's try and set the ionic up using just the Fitbit app.
