02-19-2019 12:56
02-19-2019 12:56
My ionic isn’t working unable to sync, reported it followed all instructions still not working and I get message saying my original post is getting removed? Truth hurts I think fit bit I like a full refund
Best Answer02-20-2019 00:51
02-20-2019 00:51
Did they not tell you why your post was removed? It's normally due to a breach of community guidelines (see: https://community.fitbit.com/guidelines ) and can be as simple as multiple posting.
I'm not sure what instructions you have followed so far but here are my normal troubleshooting steps:
With regards to refunds - it depends on when and where you bought it from. If you got it direct from fitbit then you have 45 days to return it for a refund but the warranty itself doesn't provide for a refund, only a replacement. If you bought it elsewhere then you need to seek a refund from the retailer.
Best Answer02-20-2019 02:06
02-20-2019 02:06
Best Answer02-20-2019 02:19
02-20-2019 02:19
As I mentioned, you can get a refund as long as you bought from fitbit within the last 45 days. The first step in a claim is to contact customer support via contact.fitbit.com
Don't forget, this is only a user community and customer support do not monitor these posts.
02-20-2019 03:18
02-20-2019 03:18
Best Answer02-20-2019 03:33
02-20-2019 03:33
This is predominantly a user based community, so those people who "don't have a clue" are just fellow users like yourself trying to give you a helping hand.
As @SteveH has posted, you will need to deal directly with customer support. They are the only ones with the authority to deal with refunds and exchanges.
