11-07-2019
14:44
08:46
SilviaFitbit
11-07-2019
14:44
08:46
SilviaFitbit
This is second time in last 2 months after a update that was rolled out that my ionic having sync issues. No suggested solutions work and i have to factory reset. It worked fine for 2 years just the last 2 months after new upgrade. Fitbit needs to fix it.
Best Answer11-08-2019 08:45
11-08-2019 08:45
@Ashionic It's great to see you around. I appreciate the details mentioned and the troubleshooting tried.
Even when your Fitbit Ionic doesn't show on your Bluetooth settings, it should sync. I would you to try this syncing troubleshooting and continue checking if it syncs as expected. Also, please check that all day sync option is on.
Keep me posted.
