08-27-2021
07:47
10:13
BraulioFitbit
08-27-2021
07:47
10:13
BraulioFitbit
My watch (Ionic) hasn't worked properly for nearly 2 weeks (since update). It only syncs about once per day and the time keeps changing randomly.
I tried wiping it and re-installing but that took numerous days and numerous attempts. Tried it on different phones, same issue.
Best Answer08-27-2021 10:28
08-27-2021 10:28
Welcome @Aisforandy It's great to see you around.
I appreciate the detailed information provided and troubleshooting performed before visiting the forums.
I recommend you to try the other troubleshooting steps that you'll find on this help article to sync your watch and time.
By the way, I've moved your post to Ionic's forum to keep the Community organized.
Hope this helps.
Best Answer08-27-2021 11:55
08-27-2021 11:55
Thank you for that.
The problem started on my Note 10. I then got a Z Fold 3 last week and having exactly the same issues.
I've tried unpairing Bluetooth, but it doesn't give me the option to pair again so I have to hard reset/wipe the watch and start again.
It can then literally take hours.
I've seen many others having the same issues since last update, so I really don't think it's anything other than a problem with the update/software.
