11-29-2018
04:28
16:21
SilviaFitbit
11-29-2018
04:28
16:21
SilviaFitbit
So my ionic keeps recording data (steps, active minutes, distance traveled, etc.) while it’s hooked up to the charger overnight. I don’t have anything plugged up next to it that could be messing with it and I’ve tried resetting it with no luck.
11-29-2018 13:17
11-29-2018 13:17
Welcome to the forums!
Is the Fitbit near a vibration source like a fan, dehumidifier, or even a computer CPU? It can see the vibration as steps and add false steps.
You can enter a driving record to get rid of them
https://help.fitbit.com/articles/en_US/Help_article/Can-I-delete-data
Check out the discussions boards! A lot going on and I'm sure you have some contributions as well!
Hope to see you around!
Wendy | CA | Moto G6 Android
11-30-2018 16:24
11-30-2018 16:24
A warm welcome to the Community @GTaylor16! I appreciate the details that you've mentioned as well for the reset that you performed.
Just as @WendyB mentioned, I would like you to confirm that your Ionic isn't near a fan or something that might be vibrating on the same surface as the device. If it is, then try placing it on a different surface and continue monitoring it.
Hope this helps! I'll be around if you need further assistance. ![]()
12-01-2018 08:33
12-01-2018 08:33
