04-21-2020
23:56
11:33
SilviaFitbit
04-21-2020
23:56
11:33
SilviaFitbit
i had two runs recently and the GPS did not registered any of the routes and it was forever searching...
04-22-2020 11:32
04-22-2020 11:32
@kindaichi It's nice to see you on the Community.
Thanks for sharing what you're experiencing with your Ionic's GPS.
I would like you to check the following:
Keep me posted! I'll be around if you have any additional questions.
05-03-2020 23:16
05-03-2020 23:16
nope still not working
05-04-2020 04:55
05-04-2020 04:55
Have the same problem with my Ionic. Was perfect until my last update on 2nd May 2020. Use it for the bike and running every day. Worked fine for 2 years!
05-06-2020 13:38
05-06-2020 13:38
I too have the same exact problem with my Ionic. GPS worked perfectly until the recent update on 2nd May 2020. I use it routinely with walking and biking for two years.
I'm no fitbit expert, however, it seems obvious the recent update "broke" the gps connectivity. Rebooting the device does not help...
05-06-2020 13:43
05-06-2020 13:43
05-25-2020 10:00
05-25-2020 10:00
Hi Maria,
>I hope they do a new update soon.
I just updated my Ionic today to Version 70.8.0. The update did nothing to fix the GPS connection issue.
The recent acquisition of Fitbit by Google already had me thinking about dumping my fitbit. This GPS screw up has pretty much sealed the deal for me. So sad...
john k
05-25-2020 10:17
05-25-2020 10:17
Hi John,
Sorry to hear you are having bother too. My GPS is back sporadically but now my times are rounded to the nearest 10 minutes for runs (not on the bike). I know I'll never make the Olympics but every few seconds knocked off a previous time is hard won so being told e.g., 50 minutes regardless if time is 46 minutes or 53 minutes is a bit soul destroying. Hoping for a solution soon!
Maria
06-05-2020 19:25
06-05-2020 19:25
The issue is the recent update of the App. Why will Fitbit not reply on this specific diagnosis rather than assume the device is not set up correctly?
07-11-2020 11:11
07-11-2020 11:11
Darn, I just bought the Ionic, and the whole reason I bought it was for the GPS. Just went for a walk down to the mailbox and back to test it. Got back, and was like "Where's the map?".
Went back out and started "Hiking". GPS Signal just blinks "searching".
07-11-2020 20:04
07-11-2020 20:04
Seems strange to have such a basic problem seemingly after a software update. I now suspect if I stand still for about two minutes it manages to locate itself and is then OK -ish. But not sure..
07-12-2020 02:25
07-12-2020 02:25
Sorry to hear that. My Ionic is much improved since the last update. The GPS doesn't work all the time, 2 days ago after much 'searching' it connected but .3k into my run it disconnected. It worked fine yday. I tried leaving the GPS on continuously for a few days ...don't know if that helped but I told myself it did!
07-12-2020 03:41
07-12-2020 03:41
07-12-2020 03:54
07-12-2020 03:54
Hello Barbara, I select the 'run' option and just leave it on all the time. It does run the battery down but I tried that for 2 days - in the house and outside. It may not have made any difference but I was so frustrated and tried that. The GPS seems to connect more quickly now and tends to hold the connectivity in most instances.
07-12-2020 04:08
07-12-2020 04:08
07-12-2020 07:11
07-12-2020 07:11
Hey Maria,
I tried that this morning. Went outside to do some yard work. Set it to run. That seems to have worked but I didn't notice how long before it started. I know it was at least 10 minutes. That is unacceptable.
I am so mad at myself right now. I torn between getting an Ionic or moving over to Garmin. I have had problems with almost every fitbit I have owned. But I thought the Ionic was going to be the top of the line and got suckered in again.
Barb
07-12-2020 07:58
07-12-2020 07:58
I tried to chat with support this morning about this. It was a waste of time. Told me the standard answer that it was probably clouds or trees blocking the GPS. Neither were true.
07-12-2020 09:36
07-12-2020 09:36
Barbara I think you can quit wasting your time. The folks at Fitbit continue to fail to acknowledge that they created the problem with GPS and the Ionic. I wouldn't expect much help.
My Ionic worked with GPS for me for two years. In May 2020 they pushed out an update and GPS has never connected again. Always, "Searching..."
To me the evidence is clear. They broke it and they won't publicly take responsibility. Maybe it's because of their new owners (Google) who likely have different priorities related to harvesting your data.
07-12-2020 09:53
07-12-2020 09:53
Well, I think we should all complain to them. Clearly they are not responding here.
08-08-2020 15:43
08-08-2020 15:43
Mine's gone off since two weeks ago.
Searches forever, finally clicks in at some point during the run, but it doesn't even draw the line anymore. It was working perfectly prior to this.
