10-25-2019
02:57
14:24
SilviaFitbit
10-25-2019
02:57
14:24
SilviaFitbit
I have had my Ionic since July 20th if this year (just over 4 months). Since the middle of September the battery life has been fluctuating, sometimes the charge will last for 4-5 days and sometimes it will last a day. The past week the charge time has gone down to the point that I am getting less than 9 hours per charge.
I am using the the Fitbit clockface Moment, the included charging cable and the charger for my iPhone. I have made sure that all the notifications, permissions, automatic exercises detection, and GPS are disabled. I even used the website to fully disable GPS. I have removed all the removable apps except the timer and relax apps, as I use these (though I have stopped using them this past week). I do not have an alarm set. I have followed the tips listed for the Ionic to improve battery life. I have even tried doing a factory reset, nothing is working to correct this issue.
@Deathloch A warm welcome to the Community. Thanks for the details mentioned and the troubleshooting tried.
I truly appreciate that you mentioned that you've had your Ionic since July. Since you've tried all the recommended troubleshooting, I've shared your post with our Support team, please continue the communication through email.
I'll be around if you have any additional question.
