08-12-2019
15:46
08:04
SilviaFitbit
08-12-2019
15:46
08:04
SilviaFitbit
I got my Ionic right when it first came out, and until it’s worked flawlessly. But a few days ago it started acting really oddly. The screen frequently acts like I’m tapping or swiping it when I’m not touching it. And when I do try to touch it it almost always acts like I touched somewhere other than where I did. For example, if I tap on the top right of the screen it will act as if I tapped on the bottom left of the screen (it’s not always that specific relation, just that it misidentifies where I’m tapping).
I tried restarting the watch by pressing and holding the buttons. That did nothing. Then I managed to navigate thru the glitches and do a factory reset on the watch. That seemed to fix the issues, the screen worked fine and everything, but after a few hours it started glitching again just like before.
Any ideas what’s wrong, and/or how to fix it?
Thanks for any help you can provide.
Also, in case it matters, the phone I sync it to is an iPhone 7 Plus.
Best Answer08-13-2019 08:03
08-13-2019 08:03
It's great to see you on the Community @Pfalmer. Thanks for the detailed information shared about your Ionic's display.
I appreciate the troubleshooting tried and for mentioning that you're syncing it using an iPhone 7 Plus. It's pretty weird that your Ionic's display isn't working as expected. In this case, I've shared your post with our Support team and they will continue assisting you through email.
08-13-2019 08:03
08-13-2019 08:03
08-13-2019 10:28
08-13-2019 10:28
Thanks for your help!
Best Answer08-13-2019 10:37
08-13-2019 10:37
I have a similar situation with my Ionic which is about 1 and 1/2 years old. I tried reseting back to factory default and my Ionic basically died. I've looked for a number to call for support but, have not found it yet.
I also went to Best Buy and talked to one of their Geek Squad guys and he said I have a hardware problem and should send it back to the factory.
Best Answer08-15-2019 17:23
08-15-2019 17:23
It's great to see you around @Okiebob. Thanks for sharing details about your Ionic and the issue you're experiencing.
I wanted to create a case on your behalf with our Support team and they've mentioned you already have a case with them, please continue the communication through email.
Best Answer08-17-2019 09:23
08-17-2019 09:23
My problem now is that I took the 24 hour trial of a different clock face as offered from your website. It was from Legnite. After the 24 hour trial, it shut off my Iconic! So, I went to the website they told me to use and tried to make payment. It came back telling me they only accept PayPal and I do not and will not use PayPal. I would be happy to pay using any other method and we are only talking about a $1.95 purchase but, they still have my Iconic locked up. Now, I don't want their product and I just want them to release my Iconic.
Can you help me out?
Best Answer08-20-2019 12:51
08-20-2019 12:51
Thanks for getting back @Okiebob. Sorry for the delayed reply.
You can perform a factory reset to delete everything in your Ionic. If you don't want to delete everything on it, you may want to contact the developer of the clock face.
