07-23-2020 23:58
07-23-2020 23:58
Dear all
my ionic was low of battery and I put it on charge.
Now after a couple of days it was on charge it Still does not work.
I tried to restart it manually pushing the left and the right down buttons but it doesn’t work. I also tried to push all the buttons, without being able to turn it on.
can you help me?
best regards
R
07-24-2020 06:29
07-24-2020 06:29
Ionic number 2 black screen, no start. I miss it. I use the app and scale 👍. I will not buy another Ionic without an explanation or help fixing one of the two sitting in my dresser drawer.
Best Answer07-24-2020 09:13
07-24-2020 09:13
I have the same issue. Battery life showed to be low around 15-10% I placed it on the charger the next day I go to put it on and the screen is black and it will NOT TURN BACK ON!! Very very frustrating honestly ive had it for almost a year and wore it everyday.
Can someone explain to me whats wrong or How to maybe fix the issue I would be greatly appreciative. Thanks!
Best Answer07-24-2020 09:39
07-24-2020 09:39
my Fitbit died during the night. Next morning I set in on the charger and my app shows it is syncing and has a full charge, but the screen is black and won’t turn on. Manual reset is not working. This is the second time this has happened to my ionic.
07-24-2020 11:16
07-24-2020 11:16
The same for me today! Start my commute with low battery thinking it will be enough and when I arrived at work 30 minutes later my Ionic was dead...
Can't charge it is totally out and I really miss it!
Best Answer07-29-2020 06:44
07-29-2020 06:44
same here. I have 52% charge but nothing works. My second ionic and I’m sick of it
