06-02-2018
21:36
06:22
06-02-2018
21:36
06:22
My watch screen won’t come on. The app says it’s still tracking my heart rate, steps, and things like that. Can anyone tell me what to do?
06-02-2018 22:02
06-02-2018 22:02
Perhaps you have the screen set to manual instead of auto - will your watch face light up when you press the button on the left side? If so all you need to do is long press that button and you should get an option to change the screen from manual to auto. Manual will only work when you press the button, auto works when you move your wrist.
06-03-2018 05:36
06-03-2018 05:36
06-03-2018 06:25 - edited 06-03-2018 06:26
It's nice to have a new member around, welcome @Jeberle2001! You had a good point @joe3175, thanks for mentioning this.
Ok, if the Quick View is set to automatically and your screen is not coming on I'd recommend restarting your Fitbit Ionic by following these steps:
Let us know if this works!
06-03-2018 06:39
06-03-2018 06:39
06-03-2018 07:13
06-03-2018 07:13
Thanks for trying the restart @Jeberle2001! Since this sounds a bit more serious, I was about to create a support case on your behalf, but I realized that your had emailed our Support Team already. I've shared your post with them, they will reply to you shortly.
If you have any questions, don't hesitate to let me know.
