Ionic stuck in a constant reboot loop
Ionic will not stop rebooting itself even after draining the battery to 0%. Once recharged ionic continues to reboot itself every 5 seconds or so. Factory hard reset (all 3 buttons held) doesn't work.
Please help.
3 REPLIES 3
i am in same boat, if your watch is over a year old without the upgraded extended warrenty, the best they well do is give a 35% off a new watch even though it is the F-ing FW that is broken not the watch, if you are under warrenty they well send you a new watch
i finally got mine to recover, you just have to keep resetting the thing with the gold all three, release the bottom right after screen turns off and wait for vibrate release all buttons, and just keep repeating that till you get a red X and then setup the device
I can confirm. My Iconic was locked into a boot cycle for 2 days and I thought it was a goner. I did what pondwater suggested and after 4 tries I got the red X. 20 mins to set up and it's working again. 24hrs and it's still working. Keeping my fingers crossed.
