Hi
I'm looking for a way to get my Ionic working again.
The watch was working perfectly until I tried to update the software.
A couple of minutes into the update the Sync was lost and my watch got stuck with the 'Fitbit ' symbol on the face.
Now I can't Sync, can't turn off.
I've tried may forum suggestions. I have even allowed the battery to deplete so as to have the watch shut down and reboot, no luck.
Without a Sync I can seem to be able to do much.
Any help would be greatly appreciated.
Thank You
Hi people
Turns there is some kind of problem with the latest software update.
I use an Android phone so it's not only IOS.
I called customer service today after four days of trying everything The best they could do was to say they are working on it... Meanwhile all I can see on my Ionic is the Fitbit logo!! I should have just ignored the update.
So be careful!!
@FERNAN67, I moved this post to the Ionic Help Forum, since it is specific to this device.
Best AnswerBe careful with update. My Ionic worked great until the update. Now its completely dead. It will not charge or do anything anymore. Fitbit wont do anything because my watch is past the warranty date other than give me a small discount on another one when it was their update that killed my tracker. I'm done with Fitbit and I'm looking at other brands.
@FERNAN67 you mention a software issue with your android app, but no mention of what the issue is?
If you see the Fitbit logo, have you tried setting the ionic up as if it is new?
Best AnswerHey Rich
No matter what I try I cant get it to work . yes I have tried to sync as a new device. The Issue is that the software update causes the Ionic to freeze and nothing you do will get it to work .
So it seems a lot of people are having problems with their watches. Myself included. So what is FitBit doing about it ??!!??
I would imagine it must be a public relations nightmare and hurtful to the company image!
So why has FitBit not come out with some kind of news or fix the problems!!??
Or am I the only one with approval watch problems??
Hi @FERNAN67 your posts were merged into one thread, so you can read all your responses more easily and any help you get will be in one place. Sorry you're having problems, but cross posting is discouraged on the forums.
Best AnswerHi @FERNAN67
I sussesfull updated my ionic but I got a big problem bellow. 😞 😞
Hi @MattFitbit
After successfull update this firmware, I used my fibit ionic normal arround 04 hours. When I waked up on the morning, My ionic won't turn on.
I see on my fitbit It's still sync to 2:22AM. I think have some problem with this firmware affect to my ionic!!!!
