Weather is in celcius I need to change to Fahrenheit. How?
Hi @GrandmaLulu To change to Fahrenheit go into your app. Tap on the account icon top right, select your Ionic from the device list, tap on the apps icon, scroll down and select the weather app, tap on settings, tap on Celsius and select Fahrenheit. Finally resync your Ionic for the changes take effect.
Tony | UK
Ionic, Versa 2, Charge 3 SE, Aria 2, Flyer, Note 9, Android 8.1, Windows 10
Tony | UK
Your welcome glad it helped. It's just a case of getting used to it and once you have done things several times you will not find it complicated.
Tony | UK
