01-20-2019 21:21
01-20-2019 21:21
I bought a new ionic this week. After fully charging it, it will not "calibrate". I have taken it out of the band and laid it every possible way on flat surfaces and it will not work. Steps are counting appropriately but the HR sensor does not work, which is one of the main reasons I purchased it. Why will it not calibrate?
01-20-2019 22:23
01-20-2019 22:23
I'm not sure why it will not calibrate, but this should be unrelated too the heart rate sensor.
Have you checked the settings on the tracker to see if the heart rate is set to on?
01-20-2019 22:29
01-20-2019 22:29
01-20-2019 23:41
01-20-2019 23:41
Some have reported that setting up the tracker fixes this.
