01-15-2020
22:51
12:25
SilviaFitbit
01-15-2020
22:51
12:25
SilviaFitbit
Hi my watch went flat and it won't charge after the latest firmware update. Does anyone know how to fix this?
01-16-2020 12:26
01-16-2020 12:26
Hi, can you leave your watch on charge for several hours and see if it responds. It should come back to life whilst on charge. Also try and do a hard reset (holding down all 3 buttons for about 20-30 seconds), you might need to do this a few times and see if there is a response.
I'll be around if you have any further issues.
12:24
16:06
01-16-2020
12:24
16:06
@QMN Welcome to the Community. Thanks for the details mentioned.
Since your Ionic isn't charging, you may want to follow the tips mentioned in this article: Why isn't my Fitbit device's battery charging?
I'll be around if you have any additional questions.
Best Answer01-16-2020 12:26
01-16-2020 12:26
Best Answer01-16-2020 17:34
01-16-2020 17:34
Hi Mark, thanks for the advice. I left the watch on charge for a few hours without any success however I did the hard reset and the watch came back to life with 9% battery and I was able to put it on charge again. It's now 100% charged 🙂
