08-09-2021 03:26
08-09-2021 03:26
So I switched over to the charge 4 a couple months back; my ionic was working fine at the time. Now the battery is completely dead. It's been on the charger for a couple days and nothing.
Is there a trick to jumpstarting it or will it wind up in my pile of dead Fitbits?
Best Answer08-09-2021 07:16
08-09-2021 07:16
@CarloN It's great to see you in our Fitbit Community. I totally understand how you feel about the charging issue that your Fitbit Ionic has experienced. By the way, thank you for trying to get it resolved before contacting our forums.
Please let me know if your Ionic vibrates when you put it on the charger. In the meantime, try the troubleshooting steps that are listed in this help article. After trying these steps, charge your Fitbit device for 2-3 hours and see if it comes back to life.
Hope this helps.
Best Answer08-09-2021 07:47
08-09-2021 07:47
Thanks for getting back to me. It does not vibrate when put on the charger. I have tried the tips in the help article. It has been on the charger for several days now. I have tried using different power sources. I have even tried a hard reset while plugged in.
Best Answer08-10-2021 04:05
08-10-2021 04:05
@CarloN Thank you for getting back and trying the recommended steps. Since the issue persists, the best way to get help for this problem is to chat with us online or give us a call. Click here to get connected and our Support team will be happy to follow up and assist you accordingly.
See you around.
