07-22-2018
16:00
05:50
07-22-2018
16:00
05:50
Since the iPhone update my ionic when you start it up it has the screen with the dots I can’t get it to do anything it doesn’t even got to the setup screen. I have tried everything they have suggested and nothing I am frustrated because I spent all this money and it sits on my dresser. Please help
Best Answer07-23-2018 05:52
07-23-2018 05:52
Hi @Antgoofy, it's nice to see you around the forums! Thanks for already troubleshooting this syncing issue between your phone and your Fitbit Ionic, nice way to go!
While reading your post, my first thought is that your Ionic might be no longer paired to your Fitbit account and that's why it's not syncing or connecting to your phone's Bluetooth. In order to solve this, please go to the Bluetooth settings on your phone and remove the tracker. In the list of Bluetooth devices you'll see the Ionic and next to it, this symbol "!". Hit the symbol and it will take you to the next step, once you're there select the option that says "Forget this device".
Once you've made sure about that, go back to the Fitbit app, go to the "Account" option in the upper right corner and select "Set up a Device". This should start the setup process for your device. ![]()
If you can't get started with your Fitbit device, usually a missing requirement is the cause. Carefully review the requirements below, if you're using the Fitbit app for iOS, Android, or Windows 10:
If you're still unable to set up, try these troubleshooting steps:
Give this a go and let me know the outcome!
07-24-2018 05:38
07-24-2018 05:38
Best Answer07-24-2018 06:03 - edited 02-11-2024 10:01
Thanks for following my tips and recommendations @Antgoofy. Since this sounds a bit more serious, I have reached out to our support team and created a case regarding your inquiry. Someone will be reaching out to you within the next 24-72 hours with next steps. ![]()
Point me out if there's anything else I can do for you in the meantime.
