08-21-2018
18:41
12:51
08-21-2018
18:41
12:51
Yesterday my Iconic stopped working, only 3 months old. Won't turn on or charge. Have tried resets with no luck.
Help
Best Answer08-21-2018 21:50
08-21-2018 21:50
Try a Factory reset using the buttons. IF that fails to help you will need to contact Suppport (link in my signature)
FACTORY RESET USING BUTTONS
On the watch, hold all three buttons for about twelve seconds. This triggers the 2-button hardware reboot after about eight seconds.
- When the Fitbit logo appears, then disappears, release the bottom right button, then continue holding the left and top right buttons until you feel a strong vibration. This indicates the factory reset was initiated.
- This process may take several seconds, and eventually, the Fitbit logo appears and the device boots and displays go to Fitbit.com/setup.
- If you fail to release the bottom right button in time, or otherwise don't follow the procedure precisely, the Fitbit logo reappears quickly and boots without factory reset.
Helen | Western Australia
08-21-2018 23:01
08-21-2018 23:01
Best Answer08-29-2018 03:08
08-29-2018 03:08
It's dead, new one on it's way
Best Answer08-29-2018 12:53 - edited 08-29-2018 12:54
Welcome on board @Floyd.P! It's great to now that a new tracker is on its way after getting in touch with our Customer Support Team.
Remember that you can set up your new tracker on your currently Fitbit account by following these steps:
In case you have some spare time, I would like to invite you to visit our Discussions board where you will find great tips and encouragement from other members and if there's anything else I can do for you, please keep me posted!
Thanks for you great help @NellyG!
Best Answer08-29-2018 18:24
09-10-2018 08:44
09-10-2018 08:44
Welcome to the Fitbit Community @CarolineVB! I'm glad to hear that the steps provided in this thread helped you.
