My Fitbit will not turn back on after shutdown. It is fully charged. It did an update of new features. After that, it stated restart for notifications. I did the shutdown and now it will not power back on. Please help
Best AnswerMy Fitbit will not turn back on after shutdown. It is fully charged. It did an update of new features. After that, it stated restart for notifications. I did the shutdown and now it will not power back on. Please help
Thank you, thought my ionic was toast after shutdown on latest upgrade
OMG....Thank you so much. I was pressing the left button and not the bottom right. Whenever I reset it before, it was just the left button. I almost bought another one. THANK YOU!!
Best AnswerI had the same problem 🤭, I wanted to buy another one - almost. It’s very stressful when it doesn’t work.
Relieved 😌
Best Answeryes this has been a problem. 2 times in last few days. After updating to latest firmware , it had been working nicely . Saturday night i shutdown my ionic after charging it to 95%. monday morning tried to turn on by pressing only left button(as it used to earlier) , nothing happened. Tried with left and bottom right for more than 10 seconds, it turned on.
The problem is dual -
1. isnt this way a soft reset? instead of normal turning on?
2. The battery dropped to 37% from 95 at shutdown. this is not normal.
anybody has any inputs/suggestions?
@rahulganatra wrote:1. isnt this way a soft reset? instead of normal turning on?
It is only a Reset if the tracker is on at the time that the two buttons and pressed & held. If the tracker is turned off, it just turns it on.
@rahulganatra wrote:2. The battery dropped to 37% from 95 at shutdown. this is not normal.
Not sure why that would be, since it wouldn't use the battery while turned off. Did you place it on the charger after it was turned back on to fully charge it?
Best Answerexactly my point. the ionic wont turn on wiht left button at all. it needs reset everytime u need to turn on from shutdown mode
also battery drained. not sure why. once turned on , i put it for charging.
weird behaviour
