Is it possible customize lap distances?
Hi there all,
Is there a way to change the fix distances to my one preference.
When i use running and then preference, it will offer me the options distance, time and calories. When using it On distance it says 1km, 3km, 5km. etc up to 42,2km.
ill wood like to add 4km or 4.5 km or any other custom distance
any thoughts please.
regards Marcel
3 REPLIES 3
@Marcel2020 It's nice to see you on the Fitbit Community. Thanks for getting in touch about this.
Currently it's not possible to customize the lap distances. However I found this idea Customise Lap Distances you could vote and comment on it, to show your support. These ideas are reviewed by our team and the status will change depending on Fitbit plans.
I'll be around if you have any additional questions. Hope to see your vote on the idea. 😀
Thanks for your answer,
After carful reading into the topic you gave to me. It seems that this  or a similar requests went back as-far as the beginning of 2018.
Don't think this is hi up the agendas.
@Marcel2020 Thank you for getting back.
I appreciate that you checked the idea posted in our Feature Suggestion board. You could learn more about our Feature Suggestion FAQs here.
