01-14-2019
20:38
09:41
SilviaFitbit
01-14-2019
20:38
09:41
SilviaFitbit
Lost gestures ability after upgrade. Some of us need that capability to light up the screen.
01-14-2019 20:44
01-14-2019 20:44
The gesture is still available. You might want to check that during the update for some reason the function has been deactivated. Long press the left button and check that Screen wake is set to AUTO
01-14-2019 20:44
01-14-2019 20:44
01-15-2019 10:06 - edited 01-15-2019 10:07
A warm welcome to the Community @LarryDS! Regarding the display, there was a little change on the way that you receive notifications, because now it automatically wake your device. You can learn more about it by checking this article What's changed in the latest Fitbit OS update?.
If you can provide me with more details about what you're not able to see on your Ionic, that would be great.
Thanks for your help @Giampi71.
Hope this helps! Keep me posted.
