08-15-2018 10:10
08-15-2018 10:10
Hey,
my Fitbit Ionic broke and i got myself another one hoping the problems with music transfer are fixed.
The last time it took me 3 days of try and error to load my music, this time it doesn't seem to work at all.
When i connect Fitbit Ionic to my Pc and establish a connection, everything usually breaks within my very first action. So for example i click on playlist, it breaks. I click on transfer music, it breaks. I try to delete playlist, it breaks.
When it suddenly transfers, it transfers 10-20 songs and breaks. After a break i need 10 trials to reset the music and to try again since fitbit shows me "transfer successfull" which is obviously not the case (it doesn't even play those 10 songs).
Since i don't want to do this for ages again, do you have any suggestions?
My Fitbit is 100% loaded and on the charger, i am running windows 10, everything is up to date and my wlan is rock stable.
Best Answer08-17-2018 05:58
08-17-2018 05:58
Hey there @humanica, it's nice to see you around the forums! First make sure that your Wi-Fi network is working correctly and that your network type is compatible with your watch. After you verify the network is compatible, plug your watch into the charger and make sure it’s in range of your Wi-Fi network. For a stronger Wi-Fi connection, move your watch closer to your router. Wi-Fi won’t work on your watch when the battery level is below approximately 25%.
To download personal music and podcasts, your watch and computer must be connected to the same Wi-Fi network. Follow the steps below to verify your devices are connected to the same network and then try again to download your playlists:
If you still have trouble downloading your playlists, complete the steps below:
Your watch only stays in transfer mode for a few minutes. If you took a few extra minutes to choose your playlists, restart the download if you don’t see “Use your computer to start transferring music” on your watch's screen. To do so, tap Transfer Music on your watch again and wait a few moments for the download to start. For best results, plug your watch into the charger before downloading music.
Give this a shot and let me know the outcome!
Best Answer08-17-2018 06:37
08-17-2018 06:37
I'm glad you took the time to reply, unfortunately this doesn't really help.
Like i mentioned the wifi connection is very strong, the watch is fully charged and still connected to the charger.
I'm nur sure what compatible in term of wifi means, my router supports the wifi interface that is used by the watch. Without this compatibilty, the watch could not connect at all.
I don't know exactly why everything breaks, since fitbit is open source and stuff, is there a way to get the error logs/to open up a bug report?
Best Answer08-17-2018 06:38
08-17-2018 06:38
Please let me know if there is any way to get the logs, even if i have to do console stuff.
Best Answer08-17-2018 07:13
08-17-2018 07:13
Thanks for getting back to me @humanica! In regards to the compatibility of your Wi-Fi, your Fitbit watch can connect to open, WEP, WPA personal, and WPA2 personal Wi-Fi networks. Your watch won’t connect to 5GHz, 802.11ac, WPA enterprise, or public Wi-Fi networks that require logins, subscriptions, or profiles. If you see a captive portal when connecting to the Wi-Fi network on a computer, the network isn’t supported. A captive portal opens a web page in your browser and could ask for a username and password, payment, or acceptance of terms. This is commonly found when connecting to Wi-Fi networks in hotels, airports, coffee shops, and other public places.
Note that you can connect your watch to a personal hotspot which lets you share the cellular data of your phone or tablet when you don’t have access to a Wi-Fi network. Additional data charges from your mobile carrier may apply.
Moving forward to what you're experiencing, see the troubleshoot steps below:
Requirements:
Transfer Music Checklist:
Note: For faster download times, you might want to avoid large playlists. The more songs you transfer under one playlist the longer download times you will experience. Should you run into an issue please let us know where in the process you get stuck.
Keep me posted, I'll be around!
Best Answer08-19-2018 05:35
08-19-2018 05:35
Thanks for making that clear, yet i had no problems establishing network connection. Like i mentioned previously, i can get some music on the watch until it breaks. My computer has wired connection, wlan didn't drop once the last 3 years and transmits ~180 Mbit through my whole flat to Ipad/Samsung S5/Iphone/Laptop and more.
The fact that you posted the tutorial again makes me belive you did not really read my post at all.
It feels like you are trying to push away responsibility, making it look like my setup is failing rather than trying to improve the product. I suggested getting the logs and creating a proper bug report or getting a hotfix. If you are not interested, i guess we might both save time and skip this conversation.
