I am having a lot of trouble with this device. I am having set up and synching problems all around here is what is not working at this time:
For the weather app, I have found I need to open the weather app on my phone, then open the Fitbit app, sync with my Ionic, then open the weather app on my Ionic and it works. I know it seems like a lot of steps, but I'm hoping it will get easier as the software continues to mature. Hope that helps for at least one of your sync issues.
Best AnswerDid you ever yet a response on why when trying to set up Wifi the app just spins with the blue circle. My WIFI won't connect even after multiple restarts, turning bluetooth off and unpairing the device. Standing next to the router etc. I only seem to sync when I am on cell and that is also buggy with the system just deciding not to sync at all without multiple restarts.
Best AnswerI never got an answer and I've switched to a different device, I'm no longer using Fitbit. I've had too many problems with the devices over the years
