10-07-2017 16:41
10-07-2017 16:41
I heard the only way for the ionic to show a Celsius temperature unit ( in the weather app) is to to chose kilometres as a unit of distance . However I always use Miles as my main measurement unit.
is there a way I can get Celsius but using Miles as a measure of distance - can this combination be done ?
thanks
10-11-2017 03:22
10-11-2017 03:22
There's no seperate setting do this, the watch language / units are based on the settings in the profile settings.
01-08-2018 13:46
01-08-2018 13:46
This is not a good situation to be in as for nearly 4 decades I have worked in miles and centigrade so I think as a new Fitbit user this is a real problem for me and hope it’s fixed very soon!
01-08-2018 14:09
01-08-2018 14:09
05-24-2018 23:09
05-24-2018 23:09
I have downloaded an app that you can manually change the temperature to Celsius without switching the distance to km. It's called WeatherCast by Chris Spooner. It's a shame Fitbit haven't done anything on their default weather app for us UK customers.
05-25-2018 01:03
05-25-2018 01:03
Thanks for this I’m going to have a look
05-28-2018 14:40
05-28-2018 14:40
I got annoyed and sent an email to support and basically they haven’t said yes or no but this is the important part of the email
At this point, this feature change is not available, however rest assured our engineer department takes into account the posts in our Feature Suggestion Forum in order to make the Fitbit experience more pleasant.
Do you you think my saying my old Samsung watch could do it made an impression?
