09-27-2021
11:47
12:04
CindyMFitbit
09-27-2021
11:47
12:04
CindyMFitbit
My Ionic will not turn on, it has full power and I tried resetting it by holding the left and bottom right button and nothing.
If you see its is fully charged in the Fitbit App and the watch is not syncing [if the battery is flat and the watch is off, it won't be] you may bee seeing a previous condition when it last synced.
@Guy_ Thanks for your assistance. @Voyeur Welcome to the Community.
I appreciate the details shared on your post and the troubleshooting tried prior posting. Additionally to what @Guy_ advised, I suggest trying the following:
Hope this helps.
Best AnswerI have the same problem. My Ionic does not display anything. I charged it for 5 or 6 hours and then tried the steps you listed above. Nothing showed up on the screen. I pressed all 3 buttons for 30 seconds then released the bottom button and nothing happened, no vibration, no display.
Thanks for stopping by @MathMan.
Thanks for the details shared in your post and for already trying to solve the issue. As the inconvenience has persisted, my best recommendation is contact our Support Team so they can look deeper into the issue and help you with this matter. You can contact them through chat or over the phone. Click here to get connected. Make sure to mention the steps you've followed, so they can help you from there.
See you around.
