12-30-2017
10:57
11:00
12-30-2017
10:57
11:00
HI!
My new Ionic is stucking updae. Screen always show fitbit logo and little blue strike on the left.
I think this is toataly dead:-(
Any idea
@Drag77 wrote:HI!
Any idea
I had mine do this too.
First:You like exit out of the Fitbit app (double click home button for idevices press that button for android)
Next:Reboot the Fitbit app and go to main screen.If the line is moving then wait till it’s done if it isn’t follow the next step
Last: Press update button in corner and try that
hope that helps
@Drag77 wrote:I think problem is my Lumia 950 Phone. I try to find a Android or apple phone.
Good luck 😉
