09-27-2017 17:11 - edited 09-27-2017 17:12
Is there a hike modie using GPS like on the surge? That was one feature I used all the time.
09-27-2017 17:15
09-27-2017 17:15
So by default it's not included on the watch. You have to go into the app, click on the icon for the Ionic at the top right. Then go to exercise shortcuts. If you remove one of the current shortcuts, there are options to add such as hiking. Hope this helps!
09-27-2017 17:15
09-27-2017 17:15
09-27-2017 17:16
09-27-2017 17:16
Thank you!
11-19-2017 20:42
11-19-2017 20:42
This worked for me only from the desktop - I was not able to do the same from my phone app.
12-18-2017 14:44
12-18-2017 14:44
Thank you! On my phone it shows all shortcuts in use. I will have to check on my desktop when I'm home
12-21-2017 12:59
12-21-2017 12:59
Thank you very much!!
12-21-2017 19:59
12-21-2017 19:59
Worked from desktop only for me as well but it's working!!! Thank youuuuuuu
01-10-2018 13:19
01-10-2018 13:19
My icon is on top left. On iphone.
09-21-2018 05:35
09-21-2018 05:35
Thank you so much! This has been vexing me for years and I had no idea all those other options were there. I was also able to add yoga!
01-10-2023 08:57
01-10-2023 08:57
Doesn't work on the app, you can only re-order existing ones, not add/remove. You have to do it on the desktop
2023 and this is still an issue
01-11-2023 06:43
01-11-2023 06:43
@ziplock9000 You added on to a very old thread on the Ionic forum, a recalled device. I looked at your profile and it looks like you are using a Charge 5. When you select your Exercise Shortcut list, there is an Edit option in the upper right (iPhone, not sure about Android). I can also swipe left on a shortcut and delete it. If you are an Android user and can't edit your shortcuts on your app, please start a new thread in the Android app forum. I just edited my shortcut list for a device on the iOS app.
Laurie | Maryland, USA
