09-25-2018 14:56
09-25-2018 14:56
I just got Ionic and I was shocked, that i cannot change volume, while using my bluetooth earphones. None of the buttons work.
Best Answer09-25-2018 18:03
09-25-2018 18:03
What bluetooth eaarbuds are you using? I've heard of some earbuds do not support the volume controls on the Ionic (my Zolo Liberty+ work fine for volume, not so much during a run)
09-29-2018 11:12
09-29-2018 11:12
It's nice to see you around @aszu77! I was wondering the same than @sfringer. Which one do you have?
While music is playing, play or pause the track or tap the arrow icons to skip to the next track or previous track (returning to a previous track isn’t possible when listening to Flow). Press the + and - icons to control the volume.
Open the music controls to change tracks or control volume. From any screen, press and hold the back button on your watch and swipe to the Music Controls screen instead of opening the Deezer/Pandora app in case you're using one of those
you can always try this troubleshoot and see if the connections works better:
- Unpair and repair the headphones
Give this a go and let me know if that works!
Best Answer12-23-2019 05:01
12-23-2019 05:01
Just bought some ear pods and can't adjust the volume. Tried this and still no good
Best Answer01-02-2020 12:12
01-02-2020 12:12
I have the same issue. I am using I7-TWS earbuds and I cannot change the music volume on my Ionic.
Best Answer01-02-2020 13:10
01-02-2020 13:10
Not seen anything grim Fitbit to say they're fixing it
Best Answer01-02-2020 14:08
01-02-2020 14:08
Thanks @Gazztop. I hope at some point Fitbit will respond. I like my Ionic but I also like my hearing. 🙂
01-03-2020 00:10
