10-24-2020
09:04
12:35
RicardoFitbit
10-24-2020
09:04
12:35
RicardoFitbit
I can’t receive text notifications. I receive every other notification just not text. Can anyone tell me how to fix that? I have a iPhone.
Moderator Edit: Formatting
12:34
08:21
10-26-2020
12:34
08:21
Hi @ChanceWayne, welcome to the Community Forums!
I appreciate the details that were shared in your post. If you haven't already done so, I recommend you to check: How do I get notifications from my phone on my Fitbit device? to see that all the necessary requirements to receive notifications on your Fitbit are correctly configured and to try some troubleshooting steps.
Looking forward to your reply.
Best AnswerHope this helps. On your watch you will need to turn off “Do not Disturb” and “Sleep Mode”
On your Watch:
1. Go to Settings
2. Scroll to Do Not Disturb & select off
3. then scroll to Sleep Mode & select off
Once this is done you will start getting the vibrations from calls and texts. (This will not affect your alarm settings. The alarm will still alert you & vibrate.) Also, make sure all notifications are turned on from your Fitbit app.
Plus, if you have an iPhone Go to Settings then Notifications. (Select the app for Phone and Messages and/or any other messenger) Make sure Allow Notifications is on and Show Previews is on Always. As well as Lock Screen, Notification Center, and Banner are all checked with a check marks.
Hope this helps.
