01-27-2019
08:45
09:13
SilviaFitbit
01-27-2019
08:45
09:13
SilviaFitbit
Hello- can you help me rectify the active minutes (which reads zero) after today's run? All other features of today's 4 miles is displayed correctly - did some troubleshooting, but problem persists. (I have an Ionic and a Blaze; ran this morning with the Ionic).
A warm welcome to the Community @Allrise99! It's pretty weird that you're not seeing any active minutes for today's run. Thanks for the troubleshooting that you performed.
I would like you to double check this article to learn more about how active minutes are tracked. Also, reply to the following questions:
- Have you tried restarting your Ionic?
- After the 4 miles did it start showing active minutes?
Keep me posted.
Thanks for getting back @Allrise99! I appreciate that you've mentioned that you have a case with our Support team, I would like you to continue the communication via email. They will continue troubleshooting this with you.
