So, my Iconic seems to get notifications from my iPhone (texts, apps, etc) BUT it does not get notifications from fitbit itself. My phone will have a banner notification that says I'm nearing my step goal, my battery is low, etc...but these notifications do not appear on the Iconic itself. Is this normal behavior? (Yes, I have fitbit app set to push notifications from fitbit along with my other apps).
Also, I noticed that the notification tab on the iPhone app has notices that are a year old. Are those notifications totally dead or am I missing something? Thanks!
Are you talking about Fitbit notifications or notifications from other apps? If it's notifications from Fitbit, that is normal behavior (apart from "Reminders To Move"), but if it's the latter, you can follow the instructions here.
one cruise ship at a time!
Hi @wxman123, how are you my friend? Thanks for the amazing help @DramaQueenDiva.
That's an excellent way to explain it @DramaQueenDiva! That's the expected behavior of the Fitbit Ionic, since it won't send a notification to your Ionic to let you know the battery status; but you will see the red bar showing off on the upper right corner or in the "Today" section. Other than reminders to move and Challenges, you usually don't get more notifications from Fitbit.
If you have more questions we'll be around.
