11-17-2017
07:47
09:14
11-17-2017
07:47
09:14
Is anyone else having an issue where your watch wants your password each time you try to do something on it? I get the security piece; but it used to just ask for the password when the watch was taken off and put back on; whereas now it's each time. Because of that, I suspect it is not providing notifications (i.e. I not longer get the reminder to get up and move and this morning my alarm didn't go off). Somewhat frustrating.
Hey there @SunsetRunner, it's great to see you around the forums! Hmm... this is weird... Is your Ionic asking for a password or your Fitbit app? What is the exact message you're getting? Password? PIN?
If you're trying to set your notifications, I'd recommend checking this article to get the step-by-step guide.
On the other hand, if you've set them up correctly but they're not coming through, note that notifications skip or stop occasionally for several reasons that don't suggest a problem with your device or the Fitbit app.
If you've reviewed the list above and can't get notifications to work, force quit the Fitbit app and reopen it to sync your Fitbit device.
Notifications should work as expected after your device syncs, do the following:
If they're still not working, let's go for this:
Notifications should work as expected after your device syncs. If they don't, continue with the next task:
Give this a shot and let me know how it goes!
Best AnswerMy issue is that my Ionic keeps asking for my password every time I try to use it; even though I continue to wear it (that appeared to be the prior time a password was requested). Because the password is not entered, the watch discontinued providing notifications such as the reminder to get 250 steps/hour and the alarm that is set does not go off in the morning. Nothing to do with syncing issues from what I can tell or the app. I’ve reset the watch a couple of times and that does not appear to fix it. Notifications are setup appropriately on watch and/or app.
Hey,
I’m having exactly the same issue. A couple of days ago this started: the ionic constantly asks me for the passcode (every 30m or so, can’t tell exactly).
I’m not sure if this is disabling notifications and whatnot, but maybe it is.
As far as I can tell there were no updates to the firmware since I started using it so it’s very strange this started happening. Is this an hardware problem?
Best AnswerI’m having the same issue too. I guess we just have to wait for a firmware update to correct the bug. Would be good to have a rep from Fitbit confirm this.
Thanks for getting back guys @Magalhas @SunsetRunner @CHill73! You must enter your PIN code at least once a day. Ionic prompts you to enter your PIN code based on your device lock setting:
Note that your card issuer may require you to re-enter your PIN code to authorize a payment.
To change the device lock setting:
Keep me in the loop!
Hey guys, let's give another shot with this, I've tested mine and I found out that the placement of the Ionic will affect if you get the PIN code or not. Remember if they are too lose, is like you weren't wearing the tracker.
Also, make sure the trackers are pretty clean, moisture or things like that might interfere as the tracker won't read your heart rate and if there's no readings, is like you are not wearing the tracker. The steps to clean your trackers can be found here.
The Device Lock feature shouldn't affect the notifications on the Ionic, so after following the steps let me know if the notifications are still missing.
Give this a shot and let me know how the trackers go.
From my experience this problem started since the last Fitbit App update for IOS a week or something ago. This problem bothered me as well and I had to disable the pin and leave it enabled for Fitbit pay only. I also tried to wear the watch tightened and clean but this didn't solve the issue.
Best AnswerI confirm that the problem for me started after the last FitBit App update as well.
Moreover it cannot be due to positioning, I've been using the watch the same way since I bought it. Also it displays heart rate readings whenever this happens.
Best AnswerBy the way don't know about the notifications issue. Sometimes in the morning I had to turn off and on the bluetooth on my iphone for notifications to work again but that havn't been happening the last couple of weeks.
Best AnswerI bought mine yesterday and I have been trying to fix the problem all morning without success. I’m feeling like returning it to the store and continue using my old Charge 2 as I never had any issues with it. For being their higher end product you would expect these bugs to be detected and corrected right away...
Just bought my Ionic yesterday and getting the same issue where each time I want to do anything on my FitBit I have to type the passcode.
Image my confusion when on my phone app it clearly said unlock once every 24 hours.
Waiting on a firmware update to fix this.
Hi again guys! The new Firmware version release includes Fitbit Pay and some bug fixes and improvements. Please follow these steps to complete the update:
For Fitbit app:
Fitbit.com Dashboard:
Start charging your device before updating it, since a firmware update can take several minutes to an hour and is demanding on the battery. Note that if you update your device at midnight (when your step count resets) you may see an inaccurate step count for 24 hours.
Give this a go and let us know if the issue with the password persists!
Best AnswerEvery once in a while my Ionic randomly decides to lock itself. I have the lock feature enabled so that if I take it off my wrist, it will lock. I like this security feature. However, there are times when I do not receive a reminder that I have set up and that is because the Ionic randomly locks out and when it locks out, reminders are not triggered. An hour or two can go by before I realize that I missed something because of this. There is no setting to change to get around this other than to disable the lock feature or have to enter the passcode each time I use the pay feature. Either Fitbit should fix this bug of random locks or it needs to add a setting by which the Ionic locks if taken off your hand, but still allows notifications/reminders to trigger.
Best AnswerI am on the current version for Iconic 27.32.10.20 and it constantly reboots itself throughout the day. As a result, it will ask for a password. My Iconic had been restarting itself constantly since I got it in March 2018.
I tried factory reset 3 times with different firmware versions already, but problem persist.
Anyone else experience this? Can Fitbit give me a better solution rather than asking me to factory reset & download the latest firmware again?
