12-16-2017
19:55
05:51
12-16-2017
19:55
05:51
Ionic Fitbit will not connect or stay connect. I receive no phone messages and no reports like sleep pattern. Very disappointed. Feel I through $300 out the window
Welcome to the Fitbit Community @Lkellio! Notifications skip or stop occasionally for several reasons that don't suggest a problem with your device or the Fitbit app.
If you've reviewed the list above and can't get notifications to work, force quit the Fitbit app and reopen it to sync your Fitbit device.
Notifications should work as expected after your device syncs. If they don't, continue with the following steps:
With the sleep stages, one thing I recommend is switching your heart rate setting to 'On' instead of 'Auto.' If the heart rate setting is set to 'On' your heart rate will always be active. Keep in mind that you need to record heart rate to calculate sleep stages. If you were to turn off heart rate, your sleep logs will go back to the classic style.
In addition, I think it's great that you update the Fitbit app to the latest version (iOS and Android). I always recommend keeping both the tracker and the Fitbit app up to date with the latest versions.
Also, please take a look at all the requirements for receiving sleeping stages in this post.
Last but not least, I was wondering if the connection you're talking about is with the Wi-Fi or you are having syncing issues?
Looking forward to your response!
