Is it possible to track my open water swims with GPS.
I did a swim today and the data was all over the place...said I had only swum 50m and I had done at least 800m if not 1km!
I can't enter a 'length measurement' as I swim in different lakes.
I was thinking to perhaps set it off as a walk or run then manually convert to swim afterwards...would that work? I really need to be able to measure my distances and other stats - it was poor today 😞
Thanks in advance
Best AnswerI tried setting it to walk to use the GPS and it didn't work. The best way I have found so far is to not set to activity - but just wear it whilst swimming. It is still not completely accurate but closer than other two methods. The need a special Open Water activity than enables GPS over water
Best AnswerI put my watch into bike mode with GPS and fastened my ionic to my dry bag The GPS trace was decent on Wednesday but the distance was way off. I swam for at least over 1 mile but the watch registered 0.18 miles. Hopefully, in the future the app should have an edit feature.
